switching to efi ..truck intake or ls1 intake for boost ???
Stick with the truck intake if you already have everything and it will fit under the hood. Most people switch to the ls1/6 intakes for clearance and looks. I've read that the truck intakes flow better than the ls1 intake.
What trans?
Your gonna need to upgrade the stock truck injectors, and if your using the truck injector wiring harness you will more than likely need to swap out the injector plugs/clips to some EV1's.
