Good scavenge pump?
Old 09-07-2014, 01:44 PM
sweet99ss's Avatar
Default Good scavenge pump?
Well I'm getting tired of screwing with the "gravity drain". Just wanting advice on good scavenging pumps that will work good and last? Give me as much info as you can and part #'s if you can please! Thanks
Old 09-07-2014, 02:29 PM
WantSOM's Avatar
I just received my turbowerx exa pump. It is one of the best pumps out there.
Old 09-07-2014, 02:45 PM
JAX04's Avatar
/thread.
Old 09-07-2014, 03:10 PM
sweet99ss's Avatar
Yep after doing some reading this is what I found as well. Thanks guys
Old 09-07-2014, 04:30 PM
stevieturbo's Avatar
Yep...Turbowerx Exa is the way to go.
Pretty much any other pump....there are bad reports.
Exa seems to have none. They're good quality, mine only draws around 4-5A, it's pretty quiet and you can mount it any position you want.
Most of the others seem to insist on vertical mounting.
Old 09-07-2014, 05:41 PM
sweet99ss's Avatar
I'm going to try out my gravity drain one more time, but to me even with my new lower profile fittings it looks like it is going to have to go uphill first to me. If I don't have success this last time I'm going with a scavenge pump.
Old 09-09-2014, 05:06 AM
samdogmx's Avatar
I ran the turbowerx base model pump for a year with no problems. Ive since moved the turbos up higher and now gravity drain so, its for sale if your interested.
Old 09-09-2014, 07:57 AM
sweet99ss's Avatar
I think I may need a mini one if I end up going with one. Will the exa mini be good enough?
Old 09-09-2014, 10:19 AM
Mini is supposed to do everything the Exa does...just smaller.
Old 09-09-2014, 01:10 PM
sweet99ss's Avatar
Huh they are the same price. why would you ever get the bigger one lol ?
Old 09-09-2014, 05:54 PM
wolfinsheepsclothing's Avatar
I ran the exa pump on my previous, low mounted turbo (S2000) with zero issures (~15k miles). Nice choice!
Old 09-09-2014, 11:59 PM
I would presume the bigger one ultimately would be under less stress and motor longevity be better, perhaps also draw less current.
But yes I'd agree if the smaller one did do everything the same in a smaller package, why would you go big ?
I didnt need a small pump, the large one was fine, so I just bought it.
Quick Reply: Good scavenge pump?
