tuning issues
tuning issues
This is what my tuner is saying
Okay, at 5 or so PSI I am making 418/408 and a lot of KR with me at just 12 degrees of timing.
It could be false know due to the exhaust dumping where it is or a rattle. But with a boosted car I hate to turn off the knock sensors in case it is real.
I can try turning them off if you want, but if you say okay and something happens I am not to be held responsible.
Any thoughts what issues could be?
Car 98z on3 non ac 76mm kit tick stage 1 cam with 317 heads 60lb injectors single walbro. Plugs gapped to .30 running 7lb wastegate spring
Any help asap is appreciated!
we turned off knock sensors, plugs are br7's. car is now making lots more power now with only 5lbs that creeps to 7....
i dont know what a/f it was "knocking" at but tuner said it had decent a/f
Thanks for your replies guys.
I had this problem before I had to buy 2 new knock sensors from GM to fix it. I had tried 2 from the parts store and they were junk and continued to show knock no matter what. Bought one sensor from gm and it took care of the #1 side then replaced the other and boom knock free.
hey ghost-1 was your car a 98? and i understand that reading a plug is the only real way to see what is happening. i picked the car up yesterday and will be pulling plugs this weekend.
