Nitrous to Procharger Build
#61
I can get the belt really tight right now. I dont think it needs to go any tighter but if it does I can definitely tension it some more.
#62
Tuning couldn't be completed. One of the fuel pumps stopped working. The graph showed fuel dropping off in the 4k range. Swapped in two aermotive stealth 340's and will be taking it back to finish tuning this week. One of the partial pulls from memory showed 690 tq around 4800 rpm at 15lbs.
Took a couple of pictures after I added my radiator shroud I made. Drove the car for the first time. Sounds freaking cool.
#67
I agree looks way better when mounted up top.
I have a 4" blower pulley and the crank pulley is a 10% overdrive. I'll be honest I have no idea what it is gonna make or if it is gonna survive
#69
Your car looks and sounds amazing! I actually like the idle Procharger sound. I guess some don't or find it annoying after awhile.
It should be standard all Procharger kits have a bracket that positions the unit up top. :::hint hint::: Procharger
Few questions.
Where did you get the bracket for your battery?
I have never heard of tapping into the water pump to the head for a steam port. What does this do? I imagine it just relieves built up pressure?
Was it an option to get a black F1 head unit from Procharger? Or did you just buy a satin unit and paint it gloss black?
Car looks great man.
-Nick
Few questions.
-Nick
#70
Few questions.
-Nick
Few questions.
-Nick
#73
Me too I dropped it off sunday night but didnt hear anything today so they probably didnt get a chance to tune it yet.
Im using a stock ls1 steam vent line that connects all 4 corners. Not sure if there is any benefit of going to the pump but i have seen others do it with no ill effects and it looks better to me than running a hose to the radiator. Plus my radiator didnt have a fitting for it.
#75
Update to this old thread. Damn didn't realize it has been two years since I started this build. Overcame a lot of hurdles and bugs along the way. There was a lot of time that passed and the car sat untouched because I would get pissed at it.
Anyways Mike@G-Force Motorsports took care of me. Id like to thank him for his patience because the first couple of times I brought it to him for tuning there were bugs and gremlins that I had to sort out.
I drove the car up there Weds after changing plugs and oil the night before and had not driven the car in several months. Mike strapped the car on the dyno and made several pulls and adjustments and these were the final numbers on my 4.5" pulley. Gonna enjoy it for a little bit then probably throw the 4" pulley on it. This was done on meth and 93 that I got from the corner store.
Ill post up a video in a bit.
#77
Yes sir. If I remember correctly one of the first pulls the tq was something like 800lbs. I had a slight misfire appear and while checking plugs and installing new wires I unplugged I disconnected one of his and didn't get another tq reading. My mistake but not really concerned about it. Last time I brought the car a couple of months ago it also made 800lb/tq.
