Oil pan drain-back fitting?
1 Post
Hi all,
I'm wondering if anyone has any suggestions for an oil pan drain-back fitting. I currently have the engine out of the car, & since I've just gotten one of these oil pan baffles, I figure there's probably not going to be a better time to add that fitting. (I'm hoping to be able to add a turbocharger within the next couple of years.)
I think that I've narrowed it down to one of three -10AN Fragola fittings, each has a Viton o-ring to help seal the fitting. IIRC, at least two of the three are -10AN to 1/2" NPT, so in theory I should be able to tap the pan for the pipe thread, use a bit of thread sealant, & be good to go, right??
Last question - Am I correct in thinking that I can use a flare cap to cap off the fitting, or should I look for something else?? (I would of course use thread sealant on that as well...)
Appreciate any constructive feedback. It's probably worth noting that I won't be able to reply to this thread until the weekend, but I'm looking forward to the replies, since I'm waiting to place an order for other parts so that I can get the right parts. Thanks guys.
If you're going to use the pan for a return, I agree with STEEPSS; welding a fitting is the way to go. Personally, I like to use the timing chain cover for oil return setups.
Im running a -12 drain line.
You can drill and tap the pan for NPT threads and run a NPT x AN adapter. I did that, then eventually removed the pan and welded a fitting in when i swapped k members.
On NPT threads, you do need to use sealant. The AN side of the fitting does not require sealant because it seals on a flare.
You can also use a bulkhead fitting designed for a fuel cell.
Neither leaked.
Neither leaked.
