Non Intercooled E98/E85 timing
I would like to hear what amount of timing and at what boost folks have been running using ethanol. Post up your combo, boost psi and what timing your were running.
Here is mine
3500lb Thirdgen Camaro
Ported 862 heads
Isky 3x12 cam
Truck intake
LM7
E100 (according to the pump, I am sure its E98)
BW S475 96mm 1.32ar
So far I am at 10psi with 11 degrees timing. Headed to the track today to bump some timing in..
Here is mine
Ported 862 heads
Isky 3x12 cam
Truck intake
LM7
BW S475 96mm 1.32ar
