Turbo Trans Am Build "The Whore"
Turbo Trans Am Build "The *****"
Starting a build thread for my 2001 Pontiac Trans Am WS6. She will be getting a stock LQ9 long block with new rings, BTR cam an valve train upgrades, and timing set. Upgrading to cometic gaskets and ARP studs. Will be running a TH400 and 9" Ford with 3.25 gears. Car has full Spohn suspension components including K-Member, A Arms, LCA's PHB, and modified Torque arm to use M9 crossmember. QA1 coil overs at all four corners, Have a chassis harness through Race Wire Solutions, car will have power windows, locks, mirrors, interior lights, and other misc. options. Will be using a Holley Dominator EFI engine management system. Still haven't decided the fuel system. I will post updates as I make them.
Before the dis-assembly:
Under the Knife:
[URL=http://s16.photobucket.com/user/TypeRB16/media/The%20Whore%20Build/DSC00755_zps7458eab6.jpg.html]
[URL=http://s16.photobucket.com/user/TypeRB16/media/The%20Whore%20Build/DSC00738_zps70a2f2dc.jpg.html]
Under the Knife:
Thanks a lot man!
Those are Corbuea FX1 Pro
Took awhile to get it this far.
I'll post them as they come. Next up finish the wiring and make sure my harness works, shifter install. Then dropping the motor in to make the hot side.
