injector help
injector help
I have a 5.3,s480,jarret cam,flat top pistons newer rods truck intake and I would guess about 20lbs on e85.i have hp tuners and will be moving to holley sometime if the stock pcm don't cooperate.i will cruise around with 91 but when im at track I will run e85.i have looked into the fic 2000s but not sure if I can get away with less injector or if this is the best suited.i want it to ideal nice but get up and make power when needed.i would like to get opinions on what everyone else runs for injectors in a mid 8 sec 3600lb street car.if there is a as good set for not as much money that would be great.thanks for the help in advance.
