first turbo car, should of got one a long time ago
i bought a camaro. 370 lq9 forged bottomend. ported 317heads and intake. pt88 mm turbo. 400 with trans brake and two step, 9 inch rearend. i'm only on ten lbs of boost now. pump gas. i am going to e85 and 15 lbs boost. what kinda power do you think it can make. i have two 340 pump and 160 lb injectors. thanks for any advive you can give me.
the car was for sale on here , here the spec.
Fully forged 370 LQ9 9.3:1 compression with stock MLS head gasket
-K-1 Technologies Forged crank
-Eagle LS1 6.125 H-Beam Connecting Rod Set with Upgraded
ARP 2000 Rod Bolts, 2.100 Crank Journal, .927 Wrist Pin
-JE Inverted Dome Pistons
- Texas speed 224/224r cam
-Ported 317 heads
-dual valve springs
-ARP headstuds
Drivetrain:
Fully built TH400 from Lonnie at Extreme Automatics with a PTC converter
-Griner Pro Tree .000 Release Trans Brake
-Hytuff Input Shaft with Special Design Oversize spline
-HYtuff Intermediate Shaft
-Roller 2.48 Gear Set
-Hardened Stator Support
-Intermediate Snap Ring case Support
-Billet Clutch Hub
-Deep Pan
-Hi Flow Filter
Custom driveshaft rated at 1200HP
Moser 9in with 3.50s or 3.73's? Detroit locker 31spline
Suspension:
- Full BMR suspension(LCA/relocators/subframe connectors/ torque arm with relocation/rear sway bar)
- QA1 coil overs up front w/300lb springs and Comp 50/50 in the rear
- Replaced ALL rubber bushings in front suspension with polyurethane along with uppers, lowers and ball joints
Turbo setup
- Custom Truck manifold setup with a freshly rebuilt PT88 .96A/R T4 flange and 4in downpipe running out the back with a dynomax bullet muffler
-BMR Turbo K member
- JGS 60mm Wastegate
-Turbonetics manual boost controller
- MSD Two step
-31x12x4 front mount intercooler with 3in piping
-60mm BOV
- Meth injection
Fuel System
160lb high impedance injectors
-Nasty Performance stage 3 kit
- 2 Walbro 340 intank fuel pump
-hotwire kit
-Billet fuel rails
-MagnaFuel billet fuel pressure regulator w/boost ref.
-MagnaFuel billet stainless steel fuel filter
-8 braided stainless feed fuel line
-6 braided stainless return fuel line
-Ported 317 heads
-dual valve springs
-ARP headstuds
Drivetrain:
-Billet Clutch Hub
-Deep Pan
-Hi Flow Filter
Suspension:
Turbo setup
-BMR Turbo K member
- MSD Two step
-60mm BOV
- Meth injection
Fuel System
-hotwire kit
-Billet fuel rails
sounds like a nice car. i whould think it should run low 10s on 10# boost without issue. and seeing how you just bought it id start there and just make sure the car is sound and working at that power level then turn it up from there. but thats me and im kind of conservative.
The following users liked this post:
The BallSS (01-16-2023)
I was told by a very known vendor on here that my twin 255's with a -8 line and 127 injectors with a base pressue of 43 psi would get to 800 hp. That is with a 6.0, PT76 and a glide. So I am going to see.
Nice buy.
I would do what Yenkomike suggested. Drive a bit and make sure it is sound.
Also, the PT turbos have been an issue recently and with it having been rebuilt may wave a flag. Some may disagree but i would keep a close eye on it.
Just my opinion.
Hope it works for you. Gotta alot of good parts on that car.
Just my opinion.
