Specific Hobbs switch??
Old 09-27-2014, 07:06 AM
JustAFooL's Avatar
Default Specific Hobbs switch??
Looking to see what switch most people are running? I'm attempting to find one through Summit but can't seem to find one that reads low PSI. Did find one but it was 45$ and I didn't think people were paying that.
Also, what's the difference in normally open vs closed?
Old 09-27-2014, 08:07 AM
conan's Avatar
Try giving Lonnie a call, his double pumper runs on a hobbs switch that comes on at 4 psi. Not sure how much he sells them for, I got my switch with his pumps.
http://www.lonniesperformance.com/
As far as normaly open and normaly closed, its the type of switch. My hobbs switch is normaly open, so the + wire is broken until it gets 4 psi then it closes and completes the circuit and turns on the second pump. So the normaly closed switch is just backwards its normaly completing the circut, and would go to an open state when is has psi on it.
Old 09-27-2014, 08:13 AM
JustAFooL's Avatar
So I'm assuming for turbo applications that you need to have a N/O switch so the circuit completes once positive boost is found..
I've already got twin walbro pumps. I've seen the Lonnie's system but it was out of my price range. I'll look to see if he has any switches.
Anyone else?
Old 09-27-2014, 08:17 AM
conan's Avatar
Your using the hobbs switch to run your second fuel pump ? Then yes, you would want a normaly open switch that closes under boost.
I ment to call Lonnie to see what he charges for just the hobbs switch, he may sell them for less than the $45 you found them for.
Old 09-27-2014, 09:02 AM
Hank Peabody's Avatar
Supposedly you can order them through your local NAPA for the best price. The prices of them have steadily gone up, used to be $25 now they're near $40 from most places.
Old 09-27-2014, 09:43 AM
JustAFooL's Avatar
Yes, this will be used to run a secondary fuel pump. I've found one one Summit that's 45$, I thought that was high but it's starting to sound like it may be the way to go. The ones that I'm seeing are NOS related though and read from 4-7 PSI.
http://www.summitracing.com/parts/no...0nos/overview/
Is there a difference?
Old 09-27-2014, 09:56 AM
Close to the same one if not the same one for $25
http://www.racepartsolutions.com/ind...part-solutions
Real Honeywell with a good connector for $35
http://www.bmotorsports.com/shop/pro...roducts_id/779
Old 09-27-2014, 10:07 AM
VIPERSLYR's Avatar
Racetronix sells them the 4 psi hobbs switch that Lonnie uses and the plug and play wiring harness. There $25 American on his site
Old 09-27-2014, 10:12 AM
Thats the winner, $25 and has the good connector rather than WW1 airplane style screw on terminals.
Old 09-27-2014, 11:19 AM
JustAFooL's Avatar
Thanks guys.. I'll be looking into racetronix as soon as I get back home.
Quick Reply: Specific Hobbs switch??
