Turbo gears can it work ????
Old 10-11-2014, 10:11 PM
Jamescassy's Avatar
Default Turbo gears can it work ????
What's going to happen ?
I have stock 5.3 with t4 turbonetics
76mm .96 ar turbo 400 TRANS with 2800 ballooning convertor . Just swapping from nitrous to turbo as we speak ? My real question is my gears for now are 411 in a 9" with fool spool and moser 31 spline axles , caltracks and
Am definately going to get a much taller tire right away . It's strictly 1/4 mile 95 SONOMA ! Any body think those gears will get me boost and out the back door ? Thanks thanks thanks !!
Old 10-12-2014, 06:59 AM
dean85gt's Avatar
With a th400, 5.3 and 3.08 gears (26" tire) i am going through the traps at 6300rpm
Old 10-12-2014, 10:17 AM
Jamescassy's Avatar
Default Ouch for me
thanks .
Old 10-12-2014, 11:40 AM
Forcefed86's Avatar
Enter your info and check. Unless your running baby boost and/or really heavy, I'd guess no.
Don't forget to factor in slippage from the converter too.
http://www.f-body.org/gears/
Old 10-12-2014, 11:56 AM
Jamescassy's Avatar
Default 275
I have another chunk with open differential and 275 gear . Is that worth putting a spool in or will that be to tall ? I'm well under 3000 # and id like to run quite a bit of boost 10# or more later .
Old 10-12-2014, 07:04 PM
Restricted User
JoeNova's Avatar
You never said anything about what tire you are running. 4.11 can work fine with a big enough tire. It'll have to be 30+ inches though.
Old 10-12-2014, 08:31 PM
Jamescassy's Avatar
Default 235/60/15
That's what I'll try . Thanks
Old 10-12-2014, 10:06 PM
Busa_rob's Avatar
Turbos LOVE high gearing. Blower and nitrous guys when making the transition always make the mistake of running too much gear. Even if it's a track only vehicle least put some 3.55s in it. When you finally do you'll be asking why you didn't do it sooner.
Old 10-12-2014, 10:30 PM
Jamescassy's Avatar
Default I'm listening
Thanks
Old 10-12-2014, 11:30 PM
Forcefed86's Avatar
Really depends what kind of power your making and how bad your converter slips.
Most can't shove a 30"+ tire in the wheel well. If you can, go for it. Should get you in the 130+ trap range with a slippy converter and 30" tires. If your running 10lbs or less I doubt you'll be trapping much higher anyway.
Old 10-12-2014, 11:47 PM
Jamescassy's Avatar
Default 315/60/15
I can fit this tire I'm trying it !
Old 10-14-2014, 01:51 PM
Jamescassy's Avatar
Default Please
Anymore real-time experience
Old 10-14-2014, 10:24 PM
9 Second Truck Club
stock48's Avatar
It's too low of gear IMO unless racing 1/8 mile with a 2nd gear start, or 1.58 first gear glide maybe. About a 3.55 is as low as I would go for a 1/4 mile car under 4k LBS.
Old 10-15-2014, 05:57 AM
rkreigh's Avatar
3.42 or 3.55 is a great gear for the turbo
my ttix turbo vette *800 rwhp* went from 10.5 to 9.8 going from a 3.90 gear and stick to
3.42 gear and auto
granted, much of that was the better launch from the auto, but clearly loading the turbos has gotten them to spool quicker and get into the meat of the torq curve earlier with the taller gears
kinda opposite of a N/A car but turbos love the load
engine will last much longer too not zinging it up but rather "grunting it" a bit
Old 10-15-2014, 06:27 AM
yenkomike's Avatar
15 years ago I ran a buick gn with a 100 octaine tune it ran 11.40s with the 3.42 gears for 2 years. I picked up a 9" axle for it and it had a 4.00 gear I thought it whould fly . it ran 11.80s . I tried to make it work but it just didn't like it . I had a stock 3.00 gear laying around and just for the street I decided to swap it in and I could not believe how good it felt so I took it to the track . ran a best of 11.08 whould run 11.20 every pass .
as a side note the best 60' it ever ran was with the 3.00 gear. 1.48 @3700#
Old 10-15-2014, 09:28 AM
gsteele's Avatar
3.42 gear and auto
With 800whp/stick/3.9gear, how soon were you able to open up the throttle in first gear or second gear? I assume you were traction limited in at least first gear. You cannot build boost as quickly with the throttle partially opened. With a 3.42 gear you can open it up quicker and you do not lose boost between shifts with the automatic. If that is what you mean by loading the turbo then I understand the statement.
Old 10-15-2014, 04:18 PM
Jamescassy's Avatar
Default :)
Thanks
Old 10-15-2014, 04:19 PM
Jamescassy's Avatar
Default :)
3.42 gear and auto
Thanks
Old 10-15-2014, 04:20 PM
Jamescassy's Avatar
Default :)
Thanks
Old 10-15-2014, 07:15 PM
STEVE PWC's Avatar
Default Gears
Im running a 275 pro and a 296/55/15 drag radial on my S-10. Rolled Quarter lip 5 inch back spacing. 373 gears spool
Quick Reply: Turbo gears can it work ????
