two turbo LS cars just under 700whp? just another sunday lol
88 notch
08 ly6 junkyard 6.0 turbo cam, cast 80mm Borg warner springs, stock head bolts and gaskets etc motor never been apart, microsquirt, 80lb injectors th400, ptc billet converter, 3.55 gears, 28 inch slicks
pumpgas meth
16psi 15deg timing
02 trans am
06 6.0 iron motor, old nitrous cam, stock heads, billet 80mm borg warner, 4l80e, stock pcm, 80lb injectors, 16psi 13deg timing ford 9 inch rear, unlocked yank converter. 8 year old valvesprings
pumpgas meth
16psi 15deg timing
02 trans am
probably yes, just throwing down a base to start making some passes, they're pumpgas and the numbers far exceeded what he had hoped for so we quit for the day
it has the stock gen4 intake, unsure of what cam actually i believe its an older brian tooley cam
.96 turbine t6 both cars
