Procharger pulley bolt keeps backing out?
F1 Procharger - I used blue locktite 242, and with the belt on the car + a buddy holding the pulley, I can torque to around 30 ft-lb, but not more... we just can't hold the pulley. After about 50 miles the bolt will start backing out.
I'm afraid of using red loctite, as the last part I used that stuff, I nearly destroyed trying to get it apart. It took a blow torch and an impact.
Any advice?
Any advice?
If room permits you could also get a boxed end wrench on it and smack the end with a ball peen hammer quickly to help tighten it. Maybe try it with your friend holding the pulley and belt to keep it from turning for extra resistance? The quick taps should be more sucessful than just a slow tighten to 30ft/lbs.
