help with turbo choice for a rear mount
I have a 98 camaro ls1 6 speed with a sts turbo kit with there base turbo which is 60 mm .81 hotside non intercooled kit but running methanol running 10 psi right now and Makin right under 500rwhp on a bone stock motor conservative tune I currently am putting a built motor in it it's a 347 forged 9.8:1 compression fast 92/92 fully ported 5.3 heads that flow 300 cfm custom grind cam so i am shooting for somewhere around 700 to 800rwhp so i was wanting some Input with ppl on here that run rear mount setups with close to the same power I am wanting to achieve wat size would work the best and I am also running long tube headers 3 in y pipe to a 2.5 single pipe the rest the way back to turbo all wrapped and blanket.
Would appreciate some feed back thanks
Search for "Zombie rear mount turbo saga" on this site. Lots of good info. The long tubes need to go. Retaining heat in the pipes/ exhaust system is especially important in a rear mount setup. If you figure out how to do this, a large turbo will spool and make the lower you are looking for. Cast manifolds or wrapped shorty headers, wrapped and/ or coated piping, and properly sized tubing will make this work. A twin scroll turbo housing with a quick spool valve will also help a lot.
