Best way to remove huron speed turbo?
Okay doing a pull my front balancer bolt cam flying out so I need to pull the turbo out of the way. The turbo itself is kind of hard to take off. What would be the easiest way to gain access to the balancer? Pull the turbo or just pull the hotside off with turbo and lower it down a bit to get to balancer?
LS1Tech Sponsor
Drop the crossover, easiest access and will have more out of the way for you to work!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
