Turbo Silverado 4WD Launch Video
Old 10-30-2014, 06:08 PM
HydroStream6's Avatar
Default Turbo Silverado 4WD Launch Video
Just a little 0-75 mph 4WD launch. Truck is a 99 RCSB Z71, 33" tires, 4.8L, LS6 cam and good hardware, S372 turbo and E85, 19lbs, 4L80e. I had a couple small leaks preturbo and a couple cold side leaks that I've finally fixed. I also upped the boost. Fixing the leaks made a HUGE difference.
It went 11.6@117 last year on 15lbs, it's a whole new animal now with the fixed leaks and more boost. Wish I could track it, but all the tracks around here are closed. Oh, gotta raise the limiter just a tad, not quite enough room between the 1-2 shift and limiter so you can hear it touch it. Will be fixed tomorrow.
Anyways, that is all.
Old 10-30-2014, 06:18 PM
gnx7's Avatar
Is it a 1500 series front/rear axles/diffs? Does a 4L80e bolt up to that transfer case? It's moving for sure!
Old 10-30-2014, 06:28 PM
Ironmancan's Avatar
Badass
Old 10-30-2014, 06:30 PM
1500 front and rear with 4L80e trans and transfer case. Eaton True Trac in the back. 3.73 gears. With the 33" tires and tall first gear on the 4L80, it will do about 60mph in 1st haha.
Old 10-30-2014, 07:48 PM
krazy4's Avatar
That looks fun!
Old 10-30-2014, 08:46 PM
Moderator
denmah's Avatar
awesome! i love 4.8 trucks
and turbo trucks
and stock computer
Old 10-30-2014, 08:58 PM
1CAMWNDR's Avatar
I am getting a 2010 1500 4x4 5.3/6l80 tomorrow. One day I want it to take off just like THAT!
Old 10-30-2014, 08:59 PM
1969x11's Avatar
Awesome!! Who built the trans?
Old 10-30-2014, 10:10 PM
operatorfailure's Avatar
That is great. One question, what transfer case are you running with your 4l80? I want to swap a 4l80 in my Yukon and keep the push button 4wd. I wasn't sure on the wiring, if if is any different on the 3/4 ton transfer case from the 1/2 ton.
Old 10-31-2014, 05:11 AM
I am not sure about the wiring. Both the tcase I took out and the one that I put in were manual tcases. Sorry
Oh and the trans is just a fresh regular rebuild with a TransGo HD2 shift kit, nothing special. Although I do wish it still retained the PWM on the lockup.
Old 10-31-2014, 06:13 AM
No worries. Amazing truck!
Old 10-31-2014, 07:37 AM
LS1Tech Sponsor
hellbents10's Avatar
Looking good, fast trucks are a blast.
Old 10-31-2014, 09:30 PM
1969x11's Avatar
I have the pushbutton np246 and all I did was swap the input shaft in the transfer case. Go ahead and put a case saver in there while your at it.I looked into buying a 3/4 ton tc but they were pricey. Input shaft and case saver was less than 200 bucks and I installed it myself.
Old 10-31-2014, 09:34 PM
That sounds good. Is it the same bolt pattern on the transmission? If so, that's the route I will probably go.
Old 11-01-2014, 07:12 AM
Yup they're the same. Just swap the tcase input shaft to the larger 80e unit and you're good to go. I got lucky and just bought a while 80e/tcase/driveshafts combo. Just had to change the lengths of the shafts and good to go. There are also simply ECU mods you can do to use the stock ECU to control the 80e.
Old 11-01-2014, 08:54 AM
Perfect. I know about the wiring and tune swap for the ecm, I did it on my 68 c10 with a 5.3/4l80e swap, just didn't know about the 4x4 differences. Just what I needed to know!
Old 11-02-2014, 06:12 AM
Eric Fischer's Avatar
That is very cool, do you have any pics of the truck?
Old 11-02-2014, 07:49 AM
RCSBTURBO4WD's Avatar
Awesome!! Did you take off in 4Hi or 4Lo??
Im about done in my RCSB 4wd Turbo Silverado, looking fwd to do something similar to that kind of take off..
Old 11-02-2014, 08:53 AM
1969x11's Avatar
You'll never need 4lo again with the turbo LOL! I dont think these trucks will run 75 in 4lo.I cant wait to get a friggen trans back in mine so I can beat on it.
Quick Reply: Turbo Silverado 4WD Launch Video
