Street Driven MWC 25.3 AES 427 Twin Turbo Glide E85 Build
Old 11-09-2014, 03:32 AM
4bangermustang's Avatar
Default Street Driven MWC 25.3 AES 427 Twin Turbo Glide E85 Build
Figure I'd make a new thread as my other one is pretty old and things have changed.
Engine: 427
Dart Ls Next block
1/2 Head studs
bryant billet CCW crank
Oliver Speedway rods
Custom Diamond pistons
ls7 Mast black labels heads
Marcella intake
Jesel rockers
Morel .937 Keyway lifts
Jesel time belt drive setup
ARE 5 stage dry sump
Custom Solid roller by Martin@Tick
Wilson hi boost 105 TB
Turbo setup:
Twin Bullseye 450-88's:
BatMoWheel
88x135 Comp wheel
96x88 Turbine
4" downpipes
1.30 A/R
Lightweight billet backplate
Polished SS exhuast housing
Custom forward manifolds made by ERIC @ MWC
Rest of the kit fabed by ERIC @ MWC
Chiseled Custom A/W 3k intercooler.
Chiseled 5 gallon water box with rule 3700.
Trans:
BTE powerglide. Redone by ATF to Stage 4 specs.
Chiseled water cooler for the trans cooler.
Neil Chance Bolt Together converter
rear/susp:
MWC Custom fabbed 9", 40 spline axles, alum center, 3.89 gear, dual calipers
MWC PHB and lowers.
Stock springs with a coil or so cut off.
Strange double adj strange shocks in rear.
front/susp:
Complete MWC RACE front-end
AFCO double adj. front shocks
Car is currently @ Midwest Chassis getting an upgrade from my 10 to a 25.3. Complete front end package, 1 piece front end, Firewall kit, and a bunch more stuff. Car left my house Oct 24th looking like this:
Eric sent me this pic today! He's moving fast!
Engine setup is iron block 408 built by Tnt Race Engines (Tom Olsen). I purchased the short block cheap new from a friend. Was going to use an AES 383 I had built, but I came across a deal on some All-Pro heads that needed a larger bore. Wish the pistons had less of a dish(-28cc), but oh well. It will be driven on the street here and there, but by no means is a daily driver. Looking to race in some street classes.
I have Mike Brown's old All-Pro 12-1 Cathedral heads. They are currently @ AES getting freshened up.
Heads came with everything needed to run a solid roller setup. Nice jesel rockers and all. I contacted Martin@Tick about specing out a cam.
Purchased a Holley High ram for my intake. Plan to have MWC weld in another set of bungs for it so I can run 16 injectors. MWC is also going to supply me a Wilson 105MM TB.
I was going to use the huron speed Twin kit, but with the motor plate and the need for room for my alt, dry sump, and fuel pump, Eric said he would prefer to start form scratch. So he is doing the entire hot/cold side for the car. It will still use the truck manifolds with v-bands. downpipes will come right out the fenders. Turbo's will be 2 6765 CEA'a. WIll be using an A/W intercooler, either a frozen boost or custom one with Garrett cores.
A pic of the Huron speed setup:
Got a good deal on a ARE 5 Stage drysump setup form a member on here. It was org for a SBC, but Eric will make a mount to use it on my ls1. I plan to run an aviaid pan as It didn't come with a pan since it was for a SBC.
For fuel I plan to run a cable drive setup. I called waterman and ordered the cable drive assembly. Plan to have MWC also set in the engine bay. Been talking to Nasty Nate about purchasing his fuel cell for the stock location. Plan to run a Magnafuel MP-4205 pump which will flow an insane amount of fuel. Plan to run the Car on E85.
Trans is a TCI 4L80e. I had FLT go through it and install a Rossler Trans brake a few years back. Pretty sure it has no billet shafts, so at some point it will prob have to go back or somewhere for a little TLC. Don't have a converter or even a company picked out yet.
That should be good for now. I'll add more info and pics later.
Old 11-09-2014, 03:56 AM
Zmg00camaross's Avatar
In to watch this looks great so far. Spend that money with Eric
Old 11-09-2014, 04:57 AM
ws602's Avatar
What computer set up are you going to use?
Old 11-09-2014, 08:07 AM
mrstepheneades's Avatar
Looks sweet
Old 11-09-2014, 11:59 AM
Holley efi
Old 11-09-2014, 07:51 PM
6 Second Club Moderator
LASTLS1's Avatar
Looks great!! Your in good hands!
Old 11-09-2014, 10:13 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Lookin' sick Brian!
Old 11-09-2014, 10:22 PM
LS1RedZ's Avatar
Wow! Def gona be a bad *** ride!
Old 11-13-2014, 03:31 AM
Some more updates
Newest pic form Eric. Looks like he got some work done in the strut towers.
Purchased a nice Fluidyne radiator setup off eBay for a good deal. Hopfully this will work good enough to keep my half filled block somewhat cool. I'll throw a fan on my oil cooler if needed later to keep the oil temps down from the filled block.
Was going to use a frozen boost A/W. But saw this one on YB and ebay and figured wtf. This way if I upgrade to a man motor with 6 bolts later, I won't have to worry about out growing the IC. It's a Chiseled Performance IC 4000. Hopefully Eric can fit it under my dash as we planned.
Ordered a set of injector bungs for my holley intake to make it a 16 injector setup, those came in today.
Old 11-13-2014, 04:38 AM
rkreigh's Avatar
very interested in your tuning experience with the 16 injector setup
I'm wanting to run pump gas 93 octane on the primary injectors and e85 on the secondary for more octane (or race gas)
I have a set of 70 lb injectors in the primary and some FIC 127s for the secondary
I'm using the Haltech to control it but the tuning tips should be similar
what injectors will you be using?
Old 11-13-2014, 04:56 AM
"MAC"'s Avatar
How much power are you wanting?
Old 11-13-2014, 01:55 PM
I'll be using some precision 160#'s as one set, not sure on the second set yet. Prob something small for now that I already have.
The injector bungs to be welded on:
about 1200 to 1400 RWHP with the current turbos and shortblock setup.
Old 11-13-2014, 09:15 PM
LS1NOVA's Avatar
Very nice! Go bigger turbo now!!!!
Old 12-18-2014, 06:45 AM
Visited the car yesterday. They were working on the 1 piece front end. Brought the intercooler with me and it's just too big to fit under the dash or in the nose. So going to sell it and build a custom one for my app.
Some pics of the 1 piece nose in the works:
Purchased a ton of parts or so it seems over the last month or so.
My new ECU:
Waterman cable drive for my fuel pump:
Purchased a new DAD's transcooler, but seeing as all my water lines are 1-1/4", I flipped it and ordered a chiseled to keep it all uniform. Rob from Chiseled has AWESOME customer service and puts out a great product.
Chiseled Trans cooler:
ordered 2 turbosmart wastegates and a race port BOV. Will prob order a second bov.
Purchased this QTP front cover awhile ago, not sure why as I don't plan to do cam swaps often, but it's CNC and does look nice
Picked up a custom oil sump pan for very cheap. IDK why I don't like it, but I just don't. But the price was right and I will run it for now.
Still waiting on my heads from AES, Will prob stop in there sometime this week or next to get an update.
Talked with Martin form Tick and he is spec'ing me out a cam.
Ordered a nasty Nate fuel cell/tank and it is ready for pickup, just need to go get it.
Old 12-18-2014, 07:57 AM
9sectruck's Avatar
DAMN.. very nice build. est. wight of the car when done?
Old 12-18-2014, 07:14 PM
I would really love to put some 76's on it! But, I am limited with the class i want to run. Not to mention I only have a 4 bolt block and a budget one at that.
Eric was picking on me yesterday and said it will prob be 3500.
Looking to race outlaw street.
http://www.midwestoutlawracingseries.com/
With twins I can't be lighter then 3300, Which I personally thought I would be, but I guess we will see.
In the grand scheme of things, I am adding a bunch of weight from the iron block, turbo's, intercooler, water, 25.3....
Also pulling a bunch of weight out of the front end at the same time. But adding more then losing :/
Old 12-18-2014, 09:08 PM
LASTLS1's Avatar
Injectors should be close in size. I think 10%
Old 12-18-2014, 09:10 PM
LASTLS1's Avatar
I would have sold you my intake ,,,16 injector set up with the injectors.
Old 12-18-2014, 09:16 PM
LOL. Didn't know it was for sale. Plus, you never text me back, feeling unloved.
Old 12-18-2014, 09:21 PM
LASTLS1's Avatar
What did you text me about?
Quick Reply: Street Driven MWC 25.3 AES 427 Twin Turbo Glide E85 Build
