Air Filter or no?
Air Filter or no?
Ok, got the turbo mounted up in the Nova but in order to keep the hot side pipes in front of the belt, it caused the front of the turbo to be about 2.5 inches away from the core support. I could cut a hole in the core support and that would give me enough room to put about a 6 inch long cone type air filter on it. Otherwise I could leave it and the core support would block anything from going in the turbo, just no filtration. Help me decide what to do. Thanks guys.
First things firsts.....
Junkyard motor or fancy built one?
Junkyard= turbo guard screen. Lookem up they are like 25 bux and a nice little deal.
Fancy built motor= cutting a hole time. Idc what ppl say I have seen and heard others talk about the subject and just a season of run time and minimum miles on the setup and the cylinder walls were trashed.
IMO most screens are junk and restrict the turbo more than a tiny filter. The pleats in an airfilter allow alot more filter area than you'd think. Even a very small filter is better than most screens.
Id' always run a filter of some sort. JY motor or not, a decent turbo isn't cheap!
If its a track only car, or you are going for dyno bragging rights, you can go with no filter.
If you plan on driving it on the street and care about it lasting, you need to go filter. As previously mentioned, even though people think a screen flows a lot, it actually is more restrictive flow wise than an air filter (not the mention is doesn't protect your turbo from dust, and very small debris). Trust me, if you drive the car on the street, these elements will be out there. Its up to you to decide if you want the filter to catch it, or if you want it ran through your high dollar turbo that was not meant to ingest it.
There was no way to fit a filter on my Nova, unless it stuck out through the grille.
I did this, yes its a small colander.......
This is how close my turbo is to the core support
I'd rather have a filter.......
Ron
[QUOTE=RonSSNova;18521293]Photos?
Ron[/QUOTE
I can't for
Can't figure out how to post pics, but my turbo air filter flange was about 2.5 inches from the core support. I could get a filter roughly 5-5.5 inches wide the most. I ended up making another turbo bracket that moved the turbo further back. It basically mounts just in front of the forward most exhaust port. This will allow much bigger filter. Just have to redivide the hot side piping now. Thanks guys, I appreciate the help.
Ron[/QUOTE
I can't for
My car actually made a little more horsepower with the air filter on it. This was with a little mpt 70 at 12.5psi or so. I would have to dig up the sheets but I think it was around 15rwhp. It's a 10" long K&N. Don't know if it was because 3/4 of the filter was in the inner fender or if it smoothed out the air or what but that's what I observed.
