700 rwhp fuel system?
looking to make 700 rwhp with a turbo set up. looking to make 15lbs of boost. will be using a 15 gal fuel cell with a 2" sump. what pump would best fit my needs with some room to grow. aeromotive, magnafuel,fuel labs or something else? looking for something that wont be maxed out. also will be using 80lbs injectors
I had 2 walbro 255 and they maxed out around 650 on the Dyno so the shop tuning my car in st as installed a 3rd 255 and then made 726 wheel befor the injectors maxed out, , this is on e85
I started having fuel problems after the 3rd so I'm switching to the dual phantom 340
For 700whp? maybe on pump gas running a high base pressure, my 2 255s maxed around 650whp but that was on e85,so I guess if I was on pump gas they would have went 700+ wheel. So yea I guess them two 267s would be good for 700 On pump gas but why push the limit? If you want to buy my walbro I'll give you a dirty cheap price, there's nothing wrong with them, ones brand new, it's just the way they ate plum in my tank so I am replacing them with a drop in unit from aeromotive so I don't have to worry about how there routed
