Need some help on why car is falling on its face, dyno included.
The PT7675 has made more power than that on smaller cube engines, so I will say back pressure too. What turbo kit is on the car? Any room for a bigger PTE or Borg unit?
i have the same kit as you, and will going most likely 380-390 cubic inch and running a pt8847, thats my current plan..i would nevvver run that small of a turbo, thats not even a considered option..i wouldnt run that turbo unless i had a 5.3 and at the max a 5.7...in my opinion you have reached the point where it just canttt flow anymore than your givin it..you defffinately need a bigger turbo for a higher hp #....btw how much lag is there on your setup? i would imagine almost none?
I saw something similar to this not too long ago
Ended up being too long of a pushrod holding the valves open
Didn't exactly fall on its face but it made the same amount of power at 5600 as it did at 6600.
Changed turbos and it still peaked the same, changed cam and it didn't make a difference, swapped lifters and pushrods and it fixed it.
Probably a slim chance that's your problem but it's easy enough to check
#32
#33
