Anyone using an S475 T4 1.0 a/r??
Old 11-24-2014, 03:24 AM
Ron_Stoppable's Avatar
Default Anyone using an S475 T4 1.0 a/r??
Anyone using this exact setup? Hows the spool up?
Old 11-24-2014, 07:15 AM
69-chvl's Avatar
I had it on a 5.3 and now the LQ9. On both it goes positive at 3400 and comes on super fast after that. I thought it would spool sooner like some of these guys rides on here but after doing some research it might be a good thing that it comes on a little late. Overall very responsive and I like it. But its huge. Wondering if a TC76/78 would of worked just as well for what I'm doing (play car).
Old 11-24-2014, 07:25 AM
yenkomike's Avatar
was wondering the same thing. I have a tc78 on my 6.0 now and it spools good below 3000 but I have been thinking about going to a t4 s475 . just to free up some top end . but I really don,t need it .
Old 11-24-2014, 08:07 AM
Forcefed86's Avatar
I see this asked all the time. You’ll never get an accurate answer with the information given. "Good Spool" Is about as vague as it gets. One person’s idea of quick spool may be a lag monster to another. Depending on the build, the same turbo may behave very differently.
How are you performing these “Spool Tests” ?
What Rpm do you see 1lb of boost? Full boost?
Starting from a stop? Are you at idle or brake boosting/trans brake?
Starting from a roll? If so, what RPM?
What gear are you in? Rear end gearing? Tire size? Weight? Converter?
Compression? Heads? Cam? Intake?
Hot side design?
Etc…
All play a huge part in “spool time”. Unless our combos were VERY similar, comparing the spool time of my T4 S475 to yours is pretty pointless.
Old 11-24-2014, 03:35 PM
boostedmali's Avatar
I have the same turbo and im debating if I should take the sc off of my lsa and bolt this thing on there. I bought it from mike turbos and mike personally said that it should work perfect when I originally bought it for my ls3.
Old 11-25-2014, 02:11 PM
68II's Avatar
I have a S475 96mm T4 1.10 housing and it lights off very fast as is. 7psi by 3,200 foot braking it. L33 218 cam 3,400rpm yank.
Old 11-25-2014, 07:37 PM
LVTUNER's Avatar
Default Sticky this one under Spool Test Info
This is a great way to help, by having as much info as possible! I like it a lot better then Ha ha
Hot side design?
Etc…
Old 11-25-2014, 10:28 PM
9 Second Truck Club
stock48's Avatar
I have a S475/83 1.25 T4 on a 6.0L and it lights off extremely quick. low 1.3 60's off foot brake with a tight SC3000 converter. Like forcefed sail lots of things come into account with spool up tho. Hot side, tune, cam, intake, are all big players. E85 also helps with spool.
Old 11-25-2014, 11:18 PM
Cant wait to get my project together my vains are iching for boost.lol
Old 11-25-2014, 11:21 PM
Old 11-26-2014, 09:02 AM
to-fst-4u's Avatar
I had one on my last fbody. 5.60@125 in the 1/8th 8.77@155 in the 1/4 with it. Lights off very fast in my application with a 347 ls1, 10.5 to 1 compression, e85, no intercooler.
Zach
Old 11-26-2014, 09:43 AM
Damm thats good stuff more motivation for me.
Old 11-26-2014, 02:40 PM
BUDGETRAT's Avatar
Zach
You have a build thread on this combo or can you give more info on it Thanks
Old 12-03-2014, 09:55 AM
to-fst-4u's Avatar
Here is a rundown of the car when I sold it and a video of when it went an 8.77.
Zach
https://ls1tech.com/forums/vehicle-c...-complete.html
Old 12-03-2014, 11:51 AM
V-seriesTech's Avatar
Hot side design?
Etc…
..if only this could be sticky'd into every turbo question post.
Quick Reply: Anyone using an S475 T4 1.0 a/r??
