do i need an oil presure switch w/stock 2000 ecm
Old 11-30-2014, 01:41 PM
stacy moore's Avatar
Default do i need an oil presure switch w/stock 2000 ecm
Found out I don't need one!
putting a 6.0 w/on3 turbo kit in a jeep wrangler and don't want to spend $45 for a sending unit I might not need if the stock ECM doesn't need one. I will hook up the jeep dash gauge sender off the same place I tapped the turbo feed by the oil filter and plug the top oil sender hole.
Thanks
Stacy
Quick Reply: do i need an oil presure switch w/stock 2000 ecm
