s480 upgrades for 1000+rwhp?
Hello have a question about my build hope you guy's can steer me in the right direction.I just finished my 99 z28 370 fully built ,ported 317s,sheet metal intake alky injection 4l80e with 9in rear,is the 84mm + race cover worth the $ to upgrade to get to 1000 rwhp on 93+meth or should I look into another turbo?
You aren't going to make 1k to the tire with a standard cover S480 for 899.... not on 93 octane pump gas with Meth..... Unless its a 6 speed car with an air to water intercooler.
Thanks for the help guy's think I'm gonna pull the trigger on the upgrade this winter and turn the wick up and see what happens, probably should have did it to begin with.
considering some of the absolute best cast wheel race cover 80mm units I have see do good to make 1050... I would say it would be Very difficult to eclipse 1k rwhp with a standard cover 80 on about anything.
And if I had to choose between the wheel and the cover... the Wheel will net a bigger gain over the cover if done one at a time.
That net'd a high 5 oh@139 ish 1/8 mile time at 3250.... so there is a possibility that a fully optimized combination with the cast 80 race cover unit could knock down a 7.9X@170-174 with the gates pinned shut running her for all she was worth.
That's encouraging.......tks.
