Boosted 5.3 cam question
Hey guys,
Wondering what cam would allow the 5.3 to hit over 600whp
Running a s400 turbo
Ls6 intake
80lb injectors
Ect..
Just not sure on what cam/springs i should go with
Ls6 intake
80lb injectors
Ect..
Restricted User
For 600whp, the stock cam will work fine.
Around 600whp I'd recommend the Isky Triple 12 from Stock48. Major powerband improvements on a 5.3 and great driveability.
Anything above that you can use one of his larger cams or get one custom specced from Martin @ Tick or John @ LJMS.
Stage 1 cam with an 83mm turbine S472 would make 650-700 to the tire, drive like a cadillac, sound like a hotrod, and run for as long as you wanted it to stay together. Great combination for that power goal. That cam kit is 719 with ti retainers... and 679 with steel. Call the shop... tell me your an LS1tech member... and I will give you 5% off the order.
