363 stroker s484 iron or alum block?
Old 12-09-2014, 05:59 PM
831jd's Avatar
Default 363 stroker s484 iron or alum block?
I want to do a ls 363ci stroker out of a 5.3 with a s484 turbo. Thinking of using the l33 alum block to help lose 80-100 pounds over the iron block. Or would the iron block still be better to run? Want to run 25psi~28 thanks
Old 12-09-2014, 06:11 PM
831jd's Avatar
Will be using Callie's rods and crank
Old 12-09-2014, 06:17 PM
Mike 02T/A's Avatar
I'm curious also! I had the same thought before, but going with a 370 or so. I don't think I'd be running that much boost though. You could also go iron and run 3-4 more pounds to cover the extra weight.
Old 12-09-2014, 06:23 PM
831jd's Avatar
True but wouldn't it be nicer to be way lighter and still be able to run those extra 3-4 more pounds? Lol
Old 12-10-2014, 09:12 AM
cptinjak's Avatar
How much power? Manifold pressure has nothing to do with what kind of stresses the block is enduring.
I would lean toward a stock displacement ls3 if you must stay with an OEM block. They're one of the strongest aluminum blocks GM made.
Jack
Old 12-10-2014, 10:46 AM
LJMSJohn's Avatar
For a 4 inch arm setup I would do an iron block if this is a street car you want to put some miles on.
Quick Reply: 363 stroker s484 iron or alum block?
