1000hp guys What intercooler do you run?
#42
No. You need to consider the area of core the air has to flow through. So on your horizontal flow 24x12x4, you only have 48 square inches of area (12x4). But on your 24x10x3.5 vertical flow core, you have 84 square inches of flow area (24x3.5). In addition, the horizontal i/c is requiring air to go through a smaller area that is over twice as long as the vertical flow's. (24" length vs 10" length).
Now there are many other factors, such as tube size within the core, fin density, etc.
#43
For reference:
I tested this 27Wx6Hx4.5T intercooler on a C6 with a procharger at 8 psi this summer.
At the top of the track, on a hotlap pass, IATs pre-intercooler were 220*F, post-intercooler were 100*, ambient was around 85*. Max pressure drop was 0.5 psi.
#44
I run the CX 4" intercooler but cut the end tanks off and made my own to distribute more evenly and has 3.5" inlet/outlets. The pressure drop is not much but I do run dual methanol nozzle's.
I run 5.21-5.28 at 138mph in the 1/8th at 3450 raceweight and 20lbs of boost.
It works.
It works.
#47
For reference:
#51
It works.
It works.
