CI for a boosted motor
I have been told to do a 4" stroke for a supercharged motor for my 99Transam . Who here has used a small CI motor and what was your results and combo ? I have a Novi 2200 supercharger just don't know what CI size to go with . Do I go with 408 and do 12-14 psi or go smaller CI and max the blower out ? My car is a 6speed if that helps
TT-TECH Veteran
I did 975ish on a 346 with an F1R worked great. If you want to stay on 93 octane shoot a little lower on the CR like 9-9.5 it will leave you some saftey and not leave hardly anything on the table. GL! And budget determinds your motor really any of them will work the bigger the CI the more TQ and the HP will be simular so the bigger CI will feel faster, but because of traction it might be slower on the street anyways, so just depends on your car and budget GL!
Restricted User
Boost is basically a replacement for displacement. There are 3 liter engines making 3000 hp. Don't over think it. Stock displacement 5.3s have made 1400 with an F1X procharger.
If you want to replace the crank, it wouldn't hurt to get a stroker crank for the same price. You can start with a 6.0 block a buy a balance rotating assembly and be done with it.
with a 6 speed and that blower, your goal wont be a problem whatever size motor you choose.
Im building a stock bottom end 6.0 with a ysi(same blower as novi 2200) and think it will make than much power through a th400.
blower flow will compensate for lack of cubes and as long as the engine can tolerate all the cylinder pressure, make all you can
the small bore blocks see to be more detonation resistant
but for 800 or less, I would try out a 370-383 as suggested
I'm going to try an LS6 stock 3.86 bore with a 4.0 stroke (got a better deal on the stroker) with studds and forged lunati crank, rods, and pistons in a 4.8 iron block
this is boring the block more than I would like, but I got a killer deal on this rotating assembly and want to go for it
good luck on your build, don't skimp on the fuel system or injectors
If you want more torque, more low rpm grunt, then go with the larger motor.
But you wont need extra capacity to make the headline numbers.
Agree with what is already posted. Honestly you could hit your power goals even with something as small as the 4.8 or the 5.3. If it were me, I'd aim for the 376 though and somewhere in the 9.0-9.5 CR. It would allow you to easily hit your power goals safely, but it also gives you room to grow if you wanted to down the road.
Would last a long time unless your driving around everywhere in boost cause that's the only time it sprays lol. Mine is 1.7 gallons and I'm running two big nozzles and don't have to fill it often.
Don't worry about psi. Shoot for a power a goal and it will make what it makes psi wise. If it makes your goal on 14psi would you be disappointed? No of course not.
