twin turbo 5.3 fuel system help
68 c10 swb with 2004 5.3 BTR springs and 218/220 560 110 cam. Twin 70/68 on 3 turbos intercooled.factory silverado intake and return style fuel system. 3/8 feed,5/16 return, silverado filter.Wanting to know which in tank fuel pump alone might support 800 HP on gas and should I need to remove the factory regulator. If so, what pump, regulator combo. Also what size/ brand injectors.
Thanks !
Thanks !
We are doing a 66 c10 shop truck will be doing a ProTouring style tank like our Fbody GTO Mustang tanks. Dropped between frame rails with Magnafuel internal pump. Feel free to give me a call can help you spec a system for your needs.
Restricted User
So you need to run the second pump to a hobbs switch to come on as you go into boost. It'll likely extend pump life and regulator life.
A controller is usually for massive pumps, like guys running big methanol pumps that need a way to turn them down so its not pushing so much fuel when it isn't running wide open.
I understand. is there a preferred fuel rail brand that has big enough runners. Also are there fuel pressure regulators that will bolt directly to the back of the inlet rail?
