If you had to choose between these 2 cams….
Just about out of funds for this year’s build. Running a 370” forged short block with untouched 317 heads, T4 1.25 S475 turbo. I run around 20-25psi on E85. 9.5:1
I have the Isky triple 12 cam. 212/212 @ 112 .56x lift. I know this is on the small side used it in my 4.8/5.3.
I also have a GM “hot cam” . Its 219/228 @ 112 .525 lift.
If you had to choose between these two cams, which would you choose…. Why?
Thanks!
Thanks!
The Hot cam looks pretty good to me for a small 6.0 cam. Lift seems a little low, split maybe a tad high. But I don't see why it wouldn't' be OK for a small boost friendly cam. Shouldn't stress the valve train much.
-thanks!
