1993 YJ Wrangler 6.0 4L60e w/ON3 Truck kit
I put a ON3 truck kit in a 1999 Z71 with Stock48s triple 12 cam and that truck was fun.
NOW I put the ON3 truck kit on my 93 Jeep Wrangler that im swapping in a 6.0 4L60e and have a few more items to finish up but figured I would share my build and a few pics.
I want the turbo to lite off quick so I went with the 70 turbo.
just the normal upgrades as follows
Stock48s 218 cam
80# injectors
400L fuel pump
LS1 intake
Pac valve springs
Alper motorsports cheep head studs
LS9 head gaskets
ON3 70mm truck kit that I modified the crossover
a 350ci V8 conversion radiator w/ Lincoln fan
Psi wire harness
some conversion adapters for mating the 4L60 to the transfer case
and I modified a set of Novacs motor mounts
ford 8.8 rear w/ 410 gear & disc brakes out of a 2000 Explorer
33" tires
And a few pics
Stock48s 218 cam
80# injectors
400L fuel pump
LS1 intake
Pac valve springs
LS9 head gaskets
Psi wire harness
33" tires
And a few pics
I have a similar YJ project underway, but it is a 5.3 with a 112 maggie. I have a few questions about suspension set up.
1.) What are you using for traction bars? The guy with the silver big block CJ (thats all over youtube) has the cal tracks bars. I am thinking about the M.O.R.E. traction bar. What are you going to use?
2.) Are you keeping your stock Trac Bars?
3.) Do you think the front shackle reversal will help in any way?
I would use Cal Track Bars.
I cut the stock trac bars a long time ago.
I have know idea if shackle reversal would help > might be a better question for the jeep forum!
