Cam Change and Tuning
Those specs are very close so you should be fine but I would take it easy and wouldn't WOT. What are you doing with the 224 cam? What did you swap it out for only 3 degrees? My son is looking for a used one
You'll be fine, I changed to a smaller cc, much higher flowing/bigger valved set of heads and my tune didn't really change, a little more fuel up top was it, it liked the same timing everywhere.
