Lets talk big turbo, 6 speed, and spooolllll
Im in the process of getting my parts together to build a rear mount setup on the C6. The car is an 05 with a brand new LS3 and a spin monster cam, and the drive train out of an 08 Z (tr6060). Im going to keep the spin monster cam 230/234 .613/.598 114 + 2 The goal until I build the motor is 650-700whp on E85. (the fuel system is already done and has been running on e85 since the new motor).
The turbo is a forced inductions billet S480 92 1.25 T4. Im using factory C6 manifolds with 2.5" vbands welded on. 2.5" to a Y then 2.5" all the way back to the turbo. 2.5" back up to the ic. The hot side will be double wrapped, manifolds coated and wrapped, the exhaust housing coated, and a turbo blanket.
Ive searched for days and all I seem to find is "they spool great", "faster than you'd think" but I dont see any dyno sheets, or logs etc. Im hoping someone has first hand experience with something similar.
I'm curious to see how this setup works for you. The S480 should be a beast. Have you read "Zombies rear mount turbo saga" thread on this site? He shared a ton of knowledge. There is a lot of what doesn't work, it should help you from repeating the same mistakes. Sometimes it's about what you shouldn't do, instead of what you should do.
I appreciate that! My rear mount build emulates a few that have been successful, but I still can't find enough info about it. Have you considered a quick spool valve? I think it would work really well on a 6 speed car. Squeeze performance is making a very nice piece. I don't think they are available yet, but they are worth the wait. I have seen one in person and was very impressed. If you are close to having the car on the road I would contact them and ask about it.
Seems like it should spool pretty quick. Cam/turbo combo are the ticket to getting a quick spool even with a 6 spd. I'm no turbo cam expert, but it seems reasonable for the setup. Call liljohn and tell him what you're putting together and get his $.02. He's a good guy to get info from.
what rear gears are you running?
I think the turbo might be a bit more lazy rear mounted but that will work in your favor hooking the power and the motor will last longer building boost higher in the rpm range
good luck, should be a beast of a car
I'd like to try a twin turbo "mid mount" and go to an aftermarket fuel cell
I'm not a fan of the vette fuel system and right behind the seats is a great place to mount the turbos and run side pipes!!
I have all the parts besides the turbo, waiting on that to be shipped still :/ as soon as that gets here the build starts.
The whole spool by 3500 rpm thing doesn't work because when are you ever WOT under 3500 rpm?
Time in seconds is a better way to look at it and can be told by data logs.
Dyno's aren't really accurate either because the load is usually alot different than on the street or track
I couldn't tell the difference between 200 rpm or 2000 rpm depending on what gear I was in, or how fast it was going.
All you can really tell is
Damn that took forever
Or oh **** that spooled quick.
So depending on what you consider spooled makes a difference too.
Well I just got off the phone with the guys over at CBI. First off extremely nice and helpful. This is a stock ls3 with cam, obviously a front mount will have better spool but you can get a basic idea. He said the turbo was hitting full boost at around 3000rpms. On 9psi it made just over 800whp
http://youtu.be/fPYp1esn8lk
