what turbo cam should i go with
Here's what I'd recommend:
223/231 .617/.598 115+5 for quicker spool and added bottom end. This would be beneficial IMO to a roll racer who needs to get out on the car you're racing quickly and not have to play catch up. The turbo you have will take over on the top end easily.
227/235 .624/.610 115+5 for added mid-range and top end power. This will also have some lope/chop to it at idle if you must have some. Slight decrease in spool time, but should still light off quickly if the tune up isn't overly rich or under timed horribly.
Cam kit with either cam, push rods and dual spring kit is 679.99.
Martin is top shelf in my book! After specing me a cam he re notified me a day later after re thinking a couple of my needs and slightly modified my grind. To me that's pure awesomeness! Lol... hope this thing turns out to be a monster!
Martin definitely knows what he is doing when it comes to turbo cars and cams....and basically everything else on them.
He did a custom cam for my LS408 Turbo and it works great.
Great service and a great custom product.
If you can live without a overly aggressive choppy idle, I think you will find the idle to be enough of a lope that you can tell a camshaft is installed.
It isn't anything crazy, and if you have to have a little chop/lope at idle the Stage 2 would be your best bet. That said, I would lean closer towards the Stage 1 with it being a 6 speed.
