How do i modify a return-less fuel pressure regulator
How do i modify a return-less fuel pressure regulator on a return-less stock fuel rail. I have a aftermarket return style fuel pressure regulator and want to control the fuel pressure from that.
I think the fuel rail is from a 1997- 1999 corvette.
Thanks Stacy
Thanks Stacy
The 99 and up Vette have the pressure regulator in the fuel filter back by the tank.
So correct, that thing you see is a fuel pressure pulse reducer thing.
When guys convert these rails to return style they remove the shrader valve and use that fitting for the return line.
