Wastegate placement.....
Old 01-10-2015, 12:53 AM
transamfreak01's Avatar
Default Wastegate placement.....
Going to start fabbing up my t6 kit on my 408 real soon. Either going with a s480 or something a little bigger. My question is, I see so many different set ups and where do you guys recommend place the wastegate (s)???? I have a million other questions but I'll just start with this for now. Thanks
Old 01-10-2015, 12:59 AM
Btw I will be following the sticky for the most of this build unless there's another amazing detailed write someone else did.
Old 01-10-2015, 06:10 AM
98Camarod's Avatar
You want the wastegate to be in line with the exhaust coming from the manifolds. So take a capital T, the long leg would be the crossover, top right is from the manifold, top left is the wastegate.
Old 01-10-2015, 10:52 AM
93camaro_zzz's Avatar
I placed mine at the merge, but dont get me wrong.... If i could do mine again, i would run twin gates iff the crossover pipes near to the exhaust manifold.
Old 01-10-2015, 11:17 AM
98Camarod's Avatar
If you do one at the merge, you could still do the same thing. Just do another merge to the wastegate below the turbo.
Ok cool that's how I saw a few of them on here and figured I would do mine that way. Now the piping will be 2.25, looking to get about 7-800rwhp with room to grow eventually as this is starting to turn into a grudge car (not that I want it to as I like driving it on the street but it's getting more and more like that). I see a lot of people running the s480 and figured I would start there unless told otherwise. What wgs do you guys think I should run with?
Old 01-10-2015, 11:19 AM
98Camarod's Avatar
I like jgs wastegates. A single 60 or two smaller 40mm will suffice.
Old 01-10-2015, 12:56 PM
I will be putting two in. I was thinking the same thing camarod just wanted to get some opinions before I end up buying these items
Quick Reply: Wastegate placement.....
