In desperate need of help to resolve boost issue.
There may be no way to adjust, but that still doesnt mean it is doing what you want, what you expect, or what you think.
Hence confirming it isnt doing anything strange.
I highly doubt the problem is some leaky exhaust valves as that wouldnt explain the w/g opening at 0psi
What I meant was I don't have a way to verify timing. I will call the dealer to see if they have a way to tell what the timing is doing. If the valves are leaking I would get combustion in my exhaust which could cause the wastegate to open and also cause my exhaust to be glowing red hot 30 seconds after start up?? I'm really grasping for straws here as I've changed everything trying to resolve this issue.
Combustion could only ever open the gate if pressure inside was high enough to do it. And if that was the case the turbo would also be spooling and creating boost.
But as you say the gate is opening at 0psi boost...that makes no sense.
Yes a leaky exhaust valve could cause the glowing, as could retarded timing, incorrect valve timing, excessively lean mixtures etc.
You need to find a way to either make a TDC pointer and use a timing light which is the best option ( although guessing a difficult one )
Or at least interrogate the ecu to see what timing it is claiming to give ( but this may not be actual )
Did you try as I asked some time ago about trying it with no hoses connected to the w/g at all ?
I spoke to the dealer and he said only way to verify timing is through the ECU with their computer system.
I have video that I will try to post when I get home.
Thanks for all the tips, Carl.
Presumably as a fairly modern fuel injected engine, it has some form of EOBD connectivity ?
Again your symptoms sound more like heavily retarded timing, or a exhaust valve related problem...but more valve timing than just poor sealing valves. They'd need to be diabolically poor..
And if they were that poor in the first place you'd have little compression and it would run bad all the time.
Compression test ?
So back to the "history" question.
When did it last run normally...or has it ever ran normally ? Or what work has been done to the engine itself ?
And how are you actually trying to tune this ?
Compression test ?
Sounds like the turbine housing is way to small for the engine. That would cause enough backpressure to open even a 15lb gate, and cause the exhaust to glow, and cause ultra quick spooling. Is the exhaust side the same size as others have run on that sled?
Compression test ?
Compression test ?
I haven't done a compression test just a leak down test.
Sled ran great last year. Machine shop had the head off to put a head shim in and set the valves. It hasn't worked right since then.
#35
. Funny thing is if I unhook the reference line to the gate it will pull hard as soon as boost comes on until I decide to let off to prevent over boost.[/QUOTE]
I would say this is the area to examine more since power is there except when boost fails.
Also, is your map sensor after the t.b.?
