Will an S480 lag more than desirable?
My buddy is putting a 5.3 or a 6.0 in his Fox and he already has an S480 because he'd planned on a 6.0 initially. Now a 5.3 has come up as an option and we're worried about spool time while street driving. Will the 43 fewer cubic inches cause this turbo to spool noticeably slower on the street?
He isn't going to all-out drag race this car at the track very much, he just wants to beat it up on the street and wants it to turn corners and handle well rather than be a top end car.
It's a matter of $350 difference and a little more knowledge about the 5.3 as it runs in a truck right now and the 6.0 is in pieces.
Like NoorJ said, turbine info would be helpful. What kind of power is he looking for? That combined with displacement is the single largest factor in determining turbo size.
Jack
Jack
I have cast s480 on my 408 and it lags from a stop and trying to build boost off the line. Good from a roll with my converter. If i had to do it over again I would of went with the 1.10 and i believe its the 92mm wheel... If i was doing a stock 5.3 / 6.0 id look into the s475 maybe with some billet wheel if the budget is there.
cam, gearing, tire size, motor size, header design and perspective are all at play.
understand a S480 with a big turbine is certainly not a high response road race style turbo haha
Still haven't heard a horsepower goal. That is one of the most crucial factors to determine if you can go smaller to improve spool, and how much smaller you can go.
Jack
Jack
Stock 5.3 or stock 6.0. Stock cam. Not sure on the gears. We're either going to try to use his 351 turbo headers or stock manifolds. Maybe a 2" hot side.
Should he consider just selling the s480, going with the 5.3 and buying a different turbo that will accomplish this goal more efficiently?
He originally bought the s480 for a 408 ford 351 stroker, but has since decided on an LS...
im not a precision fan but their 7675 style turbos light so quick and make amazing power
in a 6spd car i did 613whp on 12psi and 12deg of timing and it Lit FAST like boost at 2300 wastegate open before 3k
