Most boost on LY6 with MAF
I don't want to use an SD tune on my LY6 turbo build (if I don't have to). I like the driving characteristics of the MAF. At what hp/boost are people running into issues with the stock metering?
My goal is 800whp with meth through a 4l80e and S475
Restricted User
There are tons of factory cars that don't use a MAF. 99% chance you won't be able to tell the difference with an SD tune.
7 Second Club
I like the 2009 LS3 corvette OS for something like that since it already has the extended MAF table or maybe a 2008 Silverado OS with the enhancement applied to extend the MAF table. Either should work with a 4L80 TCM I believe if you are wanting to control the trans with the TCM, or run a manual OS with a MVB 4L80. A lot depends on your wiring harness, ECM/TCM part numbers, etc though so don't quote me on this.
