10° max mounting angle for BW S480?
Trying to mount this unit up close to the firewall. Being able to tilt the *** end down will help with down pipe fabrication.
Has anyone mounted this unit at this angle (10°) or greater? Anything I can do to allow it to be tilted more?
Turbo is a BWS480 billet ETRHO 1.25 t4 race cover.
Thanks.
Thanks.
Thanks.
Thanks.
I read Garrett called out +/- 15* on most units.
Somewhere In the Maximum boost book I believe it indicated 30* was the max.
I have read mention of the journal bearing turbos not taking as much of an angle as a ball bearing unit.
Still, I would like to hear someone with experience mounting a BW at an angle, how much of an angle, and if/how it affected its bearings.
Just found this on Garrett's site;
Basically I would need something like this but in 4". Or, have the down pipe pie cut to death..
Turbo tilted back on its axis past recommended 15°.
I would highly doubt the concern is a bearing one.
But if it is tilted too far there is a likely hood of oil building up and bypassing the piston ring and causing a little smoking.
If you can live with that I wouldnt be too concerned
I am just concerned about the bearings not liking the angle.
What is the maximum angle you think I could get away with and not have any adverse effects on turbo life? 30°?
I am not concerned with oil drain. The turbo will have more than enough angle on the drain line to gravity evac and it is a -10 line. A little puff of smoke is a non issue for me as well. I am just concerned about the bearings not liking the angle. What is the maximum angle you think I could get away with and not have any adverse effects on turbo life? 30°?
If your turbo manufacturer says 30* is acceptable than go with 30* my .02 anyways.
-10AN line is on the small side in some cases. Esp. if the fitting ID isn’t a true -10. Check the actual drain port diameter on the turbo itself and ensure you don’t go smaller than that anywhere in the system. I believe BW suggests no smaller than a 19cm (3/4”!) ID drain. Copper tubing works well for this.
I’d be more than comfortable up to 30* assuming the drain is setup correctly.
-10AN line is on the small side in some cases. Esp. if the fitting ID isn’t a true -10. Check the actual drain port diameter on the turbo itself and ensure you don’t go smaller than that anywhere in the system. I believe BW suggests no smaller than a 19cm (3/4”!) ID drain. Copper tubing works well for this. I’d be more than comfortable up to 30* assuming the drain is setup correctly.
