1700HP TT Glide 9" C6 Z06 Build
Part 7
Heat Management
When turbos are involved so is heat! This is where PTP Turbo Blankets has stepped in and Provided every solution in the book to keep ambient temps at bay under the hood and keep all the heat in the hotside! I cannot begin to tell you how impressed I am with the quality of their product and would def recommend them to anyone even if it’s just headers going on.
What you see here is:
PTP Gold Adhesive Thermal Barrier
PTP’s Adhesive Thermal Barrier Plus
PTP Fire Sleeves
Velcro Heat Insulation Sleeve
Spark Plug wire boots
Starter Heat shield
Lava Exhaust Wrap
PTP’s Adhesive Thermal Barrier Plus is incredibly thick and definitely some heavy duty stuff we will be using inside the trans tunnel.
PTP’s Velcro Heat Insulation Sleeve makes it easy to wrap any wires such as the starter wire and 02 sensor wires with ease
PTP Fire Sleeves will be utilized on all of the stainless teflon hoses being used around heat such as the oil feed lines and wastgate lines.
Starter Heat shield is a must! As the proximity of the turbo hotside is mere inches from the starter.
I chose to use Lava Exhaust Wrap on the downpipes as it has the highest direct and max contact temp limits. I also love the fact that its chemical and oil resistant and doesn’t require to be wet for assembly.
Spark plug wire boots where chosen just for extra insurance, they will be going an already awesome plug (firecore.)
Downpipes wrapped! Took me about 25min. per side and turned out awesome! You can also note that I will be dumping the wg to atmosphere.
The downpipes are going to pretty much sit right at the beginning of the tunnel and will generate a lot of heat so while the tunnel brace was off I quickly stenciled the pattern unto the PTP’s Adhesive Thermal Barrier Plus and worked up some magic! (if there’s any interest I’m sure I could work with PTP to provide a quick stick on package already cut.
The Dry sump lines will be running ever so close to the passenger side turbo and practically touching the compressor housing, just as a quick measure I utilized the Velcro Heat Insulation Sleeve (which fit perfect might I add) to shield the lines from any direct heat.
Now a big surprise! PTP decided to start production on a titanium Heat shield to fit over my manifold and also has enough flexibility to fit over most any shorty manifold setup! This piece is a work of art! I already have a vented hood which are located pretty much right above my headers so between the heat shield and that my engine bay should be extremely cool
My Turbo manifold and pedestal! Also in picture is the DKT turbine housing.
Blanket!
Manifold covered
They have also chose to begin producing blankets for the DKT Turbine housing which quite doesn’t fit a t3 or t4 blanket. So I you have these turbos this blanket is perfect for it!
Heat Management
PTP Fire Sleeves
Starter Heat shield
Lava Exhaust Wrap
Blanket!
Manifold covered
#36
Manifold and turbo blankets dry fit!
ARP Exhaust manifold studs on both sides to assist in bolts never coming loose causing a leak
Passenger side Manifold and turbo only dry fit
Full assembly for last dry fitting in engine bay and with blanket.
Now working on the passenger side which has been a bit of a pain… so I went to machine shop and had them take off a little off the top for clearance on the compressor inlet housing.
STAY TUNED MORE TO COME!
