Turbo size?
Turbo size?
I have an lsx 434, brodix br7 sts heads, mast carb intk. It will go in a tube chassis s10 weighing 2320, glide. My question is what turbo and injector size to go with? And brand? Been carburated since the 90s so I am clueless.
Restricted User
One of the billet GT55 series would be nice in that. Anything 88mm or larger should get the job done to be honest.
There are guys running 4s on motors less expensive than your heads, so I should hope you wouldn't have a problem with enough turbo.
It really helps to lock down a power goal, and work backwards from there.
Does it have to be a single turbo? Can you go twins? Do you have a manifold setup already? If so, what inlet flange do you need?
Jack
Jack
