Best cutting device for hot side tubing?
Looking to get some opinions on how to cut hot side tubing. I recently bought a craftsman 10" vertical bandsaw to cut 2.5" ss tubing and it chewed up my blade immediately. I got a metal blade and tried to slow it down with a HF Router Speed Control a bit but the motor would just ramp back up on me. I know it spins too fast to cut metal but are there any other options that don't cost thousands of dollars. I have seen similar band saws with numerous speeds but the are pricy. Anyone use a chop saw or a horizontal bandsaw on a stand? Pros and cons please?
He asked what is best
This really is a loaded question in the way we are answering especially since we don't know how the kit is being built. Stainless, mild? Mig, Tig?
I started out making some parts using a chop saw and even still fire it up sometimes. But on anything I am going to purge/Tig out of stainless a bandsaw helps me keep a square cut that helps fitup and saves time on prep.
Either way would work great!
I run a production metal cutting and fabrication business for a living.
We use band saws.
As said before. A chop saw will work fine for what you are doing. It is cost effective and flat out works.
However I stand 100% behind a proper setup band saw being the best option.
We use band saws.
That's good to here. A while back I was able to slow my miter saw down and ran a bimetal blade. I didn't really like the way it cut and felt it was a little dangerous at times making small cuts. I'll explore my options with a bandsaw.
Thanks guys for your input!
I'm about as new as can be with stainless working, but I'm kinda surprised that people use chop saws on it. Doesn't that create kind of a wide heat affected zone with stainless? I noticed that's always the first thing to be critiqued on any picture of a weld on the internet lol.
