converting Lq4 block for priority oiling?
Was talking to a guy yesterday, and he told me his engine builder is converting his engine block to priority oiling to the mains. Is this possible? He said it involves drilling a hole on the outside of the block? Anybody do this? Any pics?
9 Second Truck Club
I don't see the priority oiling hurting anything if done right but unless you are making excess of 1600 hp and or turning over 9000 RPM consistantly I don't think it will do much for you. These engines are pretty amazing in stock to near stock form. What problem are you having with your bearings?
Just curious as the 2 "LS" SCCA buds I know all have oil accumulators, big oil pumps, and improved racing baffles on basically stock LS1's. And specifically said it was to fight the bearing oil starvation issues. They appear to be holding up well with these modifications.
8 Second Truck Club
I had heard most of the bearing failures on "stockish" road course stuff was due to the factory oil pump flow falling drastically at sustained highish RPM? Also the Gforce/pickup issue on corners. Any of those customers that picked up an LSX block bolt a factory oil pump to it? Or run factory pan's and pickups on the aftermarket blocks?
The c5r block is a non priority main block and I know there have been a few of them on the track without bearing problems.
Non priority main blocks work fine if you fix the oil leakage in the blocks. Generally the lifter bores are out of round and too big and you have lots of leakage around them. I've either bored and put in .903 lifters or put in lifter bushings. You can also put in roller cam bearings, they do not require pressurized oil and make a pretty good difference.
Either way I've seen 8800 rpm on non priority main blocks with stock style oil pump.
