single turbo c10
Old 02-08-2015, 08:33 PM
70c10's Avatar
Default single turbo c10
Hey guys I know there is all kinds of info about this but I just want to make sure I'm going to do this right the first time. I need to do some sort of crank case breather system. I have the gm performance valve covers and plan on welding 2 -10an bungs to each in the back. I plan to run a hose from both sides to a vented catch can and run a hose from behind the throttle body to the ls6 valley cover with a check valve in between. Currently I only have a breather on the pass side and at idle the breather smokes. Is this how I shod do it or do you suggest another way? I have attached a couple pictures of what I currently have.
Thank you,
Attached Thumbnails single turbo c10-20150208_114531.jpg   single turbo c10-20150208_114607.jpg
Old 02-10-2015, 12:11 AM
70c10's Avatar
Anyone have any input?
Quick Reply: single turbo c10
