RHS 388 Whipple 4.0 build
Figured I would share this cool build we are working on right now.
Here is a quick rundown
RHS std deck block
Mast 305cc LS7 heads
Whipple 4.0l blower
Bryant billet center counterweighted crankshaft
GRP aluminum rods
Calico coated JE custom pistons
Jesel beltdrive
Bullet .903 solid roller lifter
PRT camshaft ground by Bullet
Jesel long pivot rocker arms
Dailey drysump oiling system
Mast 305cc heads machined for the Jesel long pivot rocker arms
RHS block,4.125 bore
Machining for .903 lifters
Bullet .903 diameter solid roller lifter
rotating asy
RHS std deck block
Whipple 4.0l blower
GRP aluminum rods
Jesel beltdrive
rotating asy
we made over 1100 on a smaller engine with the same blower but were limited on overdrive, so I would think maybe 1300+
fifth gen Camaro
wait till the real cool parts show up!!
here's a couple new pics for your viewing pleasure!
finding TDC
setting the cam timing
checking valve to piston clearance
custom age 625 head studs
Victory Titanium intake valves
ready for cylinder head assembly
finding TDC
Killer build!
Sub'd for the numbers..
And good luck with the RHS block.. Hopefully it doesn't **** coolant out the side like the other 90% of them have..
Go buy some aluminum welding rod and get ready.
Looks good
Still trying to finish up the 3.4 whipple 383 here
Compression on ours is pretty low like 9:1, hoping its pump gas friendly, so I doubt it puts up numbers like yours does
Blower is spinning right around 17k on this setup, stuffed into a c5z
as much as we can get! honestly we should be around 1300hp or so. We've made 1150 with the same blower with a Super Stock legal 327 LSX
