TT 370ci. Heads
TT 370ci. Heads
Hey guys, I'm going over my build plan and am stuck on the cylinder heads. The motor will be a 370ci. iron block, 10.8:1 compression (Run on E85) with meth injection, and twin Turbonetics 69/68 turbos. I was looking at the PRC 237cc CNC'd heads, and have a cam grind by Martin for their flow. Obviously max lift was chosen and duration as well, so is there a need for more air flow? Obviously the better the flow, the more efficient, but is there a need for crazy flow? I'm shooting for 1,300rwhp. Which will probably grow
Boosted intake charge is much denser than naturally aspirated therefore mass flow is greatly increased.
Getting that denser charge(heavier mass doesn't like to turn at high speeds) to actually turn inside the intake port and induction system is the key. Flow separation has a higher chance of occurring in a boosted intake port because of the denser charge.
Getting a cylinder head to flow the most air through a given size hole is not the main focus. Setting air speed and cross sectional area while keeping turbulence and flow separation at bay is.
