Any tips for our F2 Procharger build?
We found out our 88mm turbo was too small for our 433cuin LSX with LSX DR heads. These heads have massive flow so we ordered an F2 and hitting the forum for guys that did the big Procharger and can provide advise from experience.
I have heard of some belt issues, so did you guys go cog or ?
Thanks in advance you speed freaks.
8 Second Truck Club
The debate over f2 or f1x has been going on for a long time. I choose the f2 and run it (cog) on my solid roller 408. Makes good power.
A provoluted f2 will dominate an f1x (provoluted or not) according to SME, so thats my next blower mod.
I run it on the lsx transplant bracket and have not had one single belt issue yet.
What do you have going on man. Sounds like fun.
LS1Tech Sponsor
Farkouh/Fillippides F-1C-94
NMCA/LSX EFI Real Street Fastest Car 7.84@176
Fastest 5th Gen Camaro IRS 7.67@179
From 2012 with a cog belt
http://www.lsxtv.com/features/car-fe...en-irs-record/
From 2014 with a belt drive
http://www.nmcadigital.com/2014/09/1...s-holley-fest/
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
I love the Farks car.
Thanks for the help so far, belt slippage is a prime concern.
Any other tips is greatly appreciated.
This is what we have built so far - Dont forget this a 5th Gen VERT
- Livernois Performance Built Engine 433 CID 10 to 1 Compression
- GM LSX iron block
- Callies Dragonslayer 4.00” stroke Crankshaft
- Diamond Custom Forged Pistons
- Carillo Billet Connecting Rods
- Clevite Coated Main and Rod Bearings
- ARP Main Studs
- Cometic LSX head gaskets
- ARP Head Stud Kit
- Custom Camshaft
- CTSV-R Hydraulic Lifters
- JPP Billet double row timing chain
- Melling High-Volume Oil Pump
- Trend Pushrods 3/8” (1.35 Wall) (210 Radius 5/16 ball)
- GM LSX DR cylinder heads (2.250 titanium Intake – 1.625 Inconel Exhaust)
- PAC Titanium Retainers
- PAC Custom Beehive Springs
- PAC Titanium Bead Locks
- T&D 1.9/1.9 Ratio Shaft Rocker Set
- GM LS7 aluminum intake manifold
- Edelbrock elbow
- GM 90mm throttle body
- Alcohol Injection meth kit
- Jake’s transmission 4L80 Stage 5 with transbrake
- Jake’s 3600 stall converter
- B&M magnum ratchet shifter
- Dynatech one piece aluminum driveshaft
- G force 9" fabricated IRS rear end with 3.73 gears
- ID 1000 Fuel injectors
- Squash Return High HP Fuel System
- F2 Procharger just being installed now
- GM LSX iron block
- ARP Main Studs
- ARP Head Stud Kit
- Custom Camshaft
- Edelbrock elbow
- GM LSX iron block
- ARP Main Studs
- ARP Head Stud Kit
- Custom Camshaft
- Edelbrock elbow
- GM LSX iron block
- ARP Main Studs
- ARP Head Stud Kit
- Custom Camshaft
- Edelbrock elbow
8 Second Truck Club
If its running right, you'll run out of injector pretty quick with that F2. A lot of people don't realize how much extra fuel a procharged deal takes compared to a similar power turbo deal. An F2 will take anywhere from 250-300 hp just to turn it. Thats horsepower that requires fuel but does not show up at the crankshaft or tire. Step up to some ID2000's and you should be good to go provided your pump(s) keep up. I run twin 4303 pumps on mine with ID2000's.
The squash return system seems proven for high HP.
Blown are you running a cog or serpentine belt?
Any other tips are welcomed because no many run F2s and get over the 1000 rwhp on a street car.
Thanks
Thanks
