Radiator expansion tank
Need some help with setting up my expansion tank my set up is meziere electric race pump with a dual pass radiator with -16an lines. I'm running the steam vents to a block with -4an and out of the block to the expansion tank with a -6an line. What size line to I need from the tank to the radiator and where does it need to go in the radiator?
No spot on the radiator. I was just going to weld a an bung on the radiator and I really don't want to mess with the pump since it's a meziere electric race pump. Also the radiator does not have a fill cap since I'm running a expansion tank and over flow
ah ok i forgot about the electric pump. I would read up on this. Good info!
http://www.yellowbullet.com/forum/sh...d.php?t=621363
