Powder Coated or Paint Polished SuperCharger & Tubing
I'm looking to Powder Coat or Paint My Polished Supercharger and tubing Matte Black to match Vehicle and less noticeable. Question is has anyone Powder Coated the casing, how far did you tare it down. OR should I just have the body shop paint it.. IF it would last.. Any input would be greatly appreciated..
God Bless
John Junkins
God Bless
John Junkins
I think A&A were offering factory black units for a while.
They arent hard to take apart though, but painting is probably easier, and no reason for it not to last.
Not sure which supercharger you have but I would suggest powder coating.
Most superchargers have aluminum bodies. Aluminum is more susceptible to expansion when it gets hot. Paint doesn't like expansion and contraction, it will crack. Powder coating is more tolerant of expansion and contraction.
If you powder coat you would need to tear it down completely.
Good luck
Good luck
I recently did my water pump with VHT wrinkle black paint. It turned out pretty decent. I don't know about the expansion and contraction tolerance, but it would be easier to do than powder coating, since you wouldn't have to tear it all down and possibly mess up putting it back together.
Andrew
Andrew
That's the look I'm looking for^^^.. Don't know how hot my blower get being oil feed.. If I have to disassemble it mine as well rebuild it.. It's a used low mileage unit I purchased off here.. Might talk to my powder coat guy today and see how to go about this.. Engine paint???
God Bless
John Junkins
God Bless
John Junkins
God Bless
John Junkins
God Bless
John Junkins
The VHT wrinkle paint is pretty tough. People use it on all kinds of engine components. I can't imagine it would be a problem on your blower.
Andrew
Looks for some tips online as to how to do the wrinkle paint. I sprayed mine fairly think in three coats, like the directions said, then I took a heat gun to it to make the paint wrinkle up. Then I let it sit overnight and then baked it.
Andrew
The VHT crinkle finish needs the heat to achieve the crinkle, if you just wanted plain flat paint, I dont think you do heat it up.
I sprayed some old ls1 valve covers I had in duplicolor truck bed coating in a spray can from Walmart for $10 and they looked great. I also had another set powder coated in a wrinkle black color for $65 from the local specialist. They turned out fine but looked almost identical to the truck bed coated ones for a lot more $. I cant say how long the truck bed coating will last on aluminum but I sprayed the inside of my kids lil red wagon over 5 years ago and it still looks good being left out in the weather every day. I just roughed up the inside with a scotch brite pad to knock the surface rust off and wiped it down with a dry rag before shooting it. I bought a 4l80 conversion dipstick from Madman racing and used the truck coating on it. I wiped it down with a rag and mineral spirits to get the oil film off the bare metal and sprayed it. The truck bed coating dried rock hard with no primer under it on bare metal and looks as good as my powder coated valve covers do. I have actually thought about coating my Procharger headunit with it. I am going to coat the FMIC piping though.
I painted just about every thing I could on my last build, I used 4 different paints. VHT 2,000 deg flat black on the brake calipers and exhaust. VHT 900 deg gloss red on the brake caliper brackets. Stainless steel paint from my hardware vender, for some engine parts. Then I got Valspar "Senia Red Pearl" enamel paint mixed up in a rattle can, the paint shop I bought it from used a hi-heat additive. I used this paint for the J-bracket, oil pan, water pump, rocker covers, intake manifold, motor mounts. No problems with anything pealing off. I was a little nervous painting the Y pipe and cat back exhaust with the flat 2,000deg paint but after 1,000 miles of driving and a dyno tune session the exhaust looks like it did the day I painted it.
Prep is the key to making this last for you. I took a wire brush on a die grinder and went to town on everything, then a light scuff with some 800-1,000 grip sand paper. Wiped everything down with acetone then painted.
I wouldn't hesitate to paint my blower with any of the 4 paints I used on the rest of the car. The oil pan and water pump get pretty hot, same with the brakes and exhaust. Just take your time, disassemble everything, and clean, clean, clean the paint surface.
Here are a ton of pics from my build with every thing I painted https://camaroversion20.shutterfly.com/
