CX Racing Intercoolers
Does anyone have any experience with CX Racing's W2A intercoolers? The one I'm looking at's only 275 bucks, and from Spearco and such places it'd easily be over 1,000 bucks! Will they hold up and cool good for high-horse applications?Iced water will be ran through it as well as having a heat exchanger.
How much power do you plan on making and at what boost levels?
Unless it's an all out drag car I can's see needing an A2W unit. It's just not needed for most. If your dead set on it I wouldnt' think twice about using a cheaper CXracing core, as you won't need that much charge cooling with twins and E85 anyway. The better cores are 3-5x as expensive and usually only cool 10-20% better with less pressure drop from what I've read. That's huge when hundredths of a second count... but not worth it for a street/strip car IMO.
The original goal was 1300 to the ground, but everyday that grows.. I'm building it to hold up to that kinda power, I'm not just throwing some **** together and hoping it'll hold. It'll mostly be a street truck, so ET's don't really bother me too much, but I would like my charge setup to be as efficient as possible.
Lastly 1300+whp on the street is totally pointless. (esp with caltracks and 29” drag radials!) You’re not going to be able to put that power to the ground, so why bother? Assuming you ever got it together, You’d have a very expensive tire smoke machine.
Many of these threads with 1000+HP goals lately are laughable! Most don’t have a clue what it actually takes to make parts live at these levels. I don’t’ say this to be rude, and I’m not saying you are one of these people either... Saying it because it’s the truth.
Best of luck with your build. It will need serious revamping if you want to reach your goals.
The following users liked this post:
DNowak (10-20-2020)
Your goals sound very unrealistic to me. After looking over your build thread/parts you are severely lacking in quite a few departments to meet 1300+whp goals on E85. If you’re really planning on 1300+whp you better throw an aftermarket block in that build plan. A bored 370 OEM iron block isn’t going to last at those power levels… Esp. at your chassis weight. (cyl walls are too thin) A single Holley 1800 will make nowhere near that kind of power. You’ll need 60-65psi base pressure to make anywhere near 1300whp on 160lb injectors. Your 66mm turbos aren’t sized properly for your top end/cubes/power goals either.
I dont think the intercooler is going to play that much into the ekvation since he's running on E85 , i have even seen non intercooled 10:1 E85 run 700+ CSB with boost. the injectors and pump will be on the small side. the Holley pump is probably safe to 900whp on E85.
Didn't Denmah use the CXracing ? at 600 - 700whp ?
Based on the past results of other Chinese parts, id imagine the A/W from CX would do pretty good at "lower" power levels like this though
DNowak (10-20-2020)
